756 Gas doesn't get warmed up in cold weather
Posted by CDB on February 04, 2015 at 13:59:50 from (69.80.124.120):
My 756 temp gauge never moves when I use it to plow my drive. I plug it in and let it warm up in the barn before I use it. It will sputter and die unless I have it partially choked. It works fine in warmer temperatures. I put a new thermostat in it a couple years ago. I know these 6 cylinders are cold blooded. Can I safely put cardboard, or plastic..or ??? in front of the grill to limit cold air coming in so that it will warm up and run better?
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
