It should bolt right up if you have the correct mount on the torque generator. Are you running the pump off the tractor hydraulics or off a eaton style pump? I wouldn't go and cobble up the throttle assembly on a smd just to put a power steering unit on it. It is getting harder to find the throttle assemblys intact and in decent shape. If the torque generator doesn't fit right hold up and look for one that will. Most md's and smd's I have seen with power steering use a charllin style torque generator mounted under the hood and they use the factor throttle assembly. Most behlen set ups I have seen are on gas tractors and mounted on the steering post at light bar and I think if your using that set up you may have clearence issues. Good luck.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
