Posted by gqjoe on February 04, 2015 at 22:28:00 from (173.210.167.202):
I wanted to post an update on my progress with my 17gpm pump upgrade in my 606. I installed the new pump and suction tube and it went together very easily. On the filter side input on my filter extender kit but noticed that the filter had a large opening on the exterior side. After some research I found out that I needed to order a filter bypass valve before I put the filter, extension and lid on the tractor. I did that and that side went together very nicely too! Also when putting on a dry pump I filled it with oil through the hole where the filter attaches until it came out before I put the filter in. It started and now it sounds way way louder than it did before. It whines and it seems to get a little quieter when I steer left or right. The whining also seems to be coming not from the pump below which I would say indicates gears clashing but it's coming from the flow divider valve area. I'm hoping I could get some help with this yet as to what I should check out or test.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
