Re: Farmall 240 versus 200 engine
Posted by Truckpuller83 on February 05, 2015 at 04:03:01 from (76.3.243.86):
In Reply to: Farmall 240 versus 200 engine posted by gmanzo on February 05, 2015 at 01:26:02:
I put an engine from a 240 into a Super C. You need to check the water pumps closely as I believe the 200 and the Super C use the "side" mounted pump, where the 240 had an engine mounted pump (99% sure). If the water pump locations are the same you will be good to go.If not, it will take some "engineering" to make everything work up front (radiator hoses, fan, etc...). It can be done but it may not be "factory". There are some very helpful archived posts on Super C engine swaps that may (or may not) apply in your case. I'm sure someone will weigh in that knows a bit more than me.
  Upload Photo  Select Gallery Photo  Attach Serial No List
