Saw a few with a gas throttle but didn't see under the hood to see how they worked it. Saw more converted to the 400, 450 type throttle. But that runs into clearance problem with the power steering at rear also. Really the gas units rub the steering unit or are bent to clear. If the throttle works okay one thing to try is find a extra MD shaft and modify it to clear. Think you could build a offset if needed that placed right with the throttle ark would work.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
