Re: hydraulics wont work in winter on 460 is 303 fluid ok to use
Posted by Nebraska Cowman on February 05, 2015 at 18:06:57 from (66.252.116.102):
In Reply to: hydraulics wont work in winter on 460 is 303 fluid ok to use posted by john pabst on February 05, 2015 at 12:07:54:
303 is 20w oil. Like Allan I have found it gets
pretty thick in cold weather.
The 460 uses a filter on the suction side of the
pump. Any moisture in the oil or dirt in the
filter and the pump starves for oil. You will
probably need to change the filter at least every
fall if you want it to work in the winter.
  Upload Photo  Select Gallery Photo  Attach Serial No List
