Re: farmall m mw handclutch and hydraulic pump??
Posted by DeltaRed on February 06, 2015 at 07:01:16 from (65.100.146.228):
In Reply to: farmall m mw handclutch and hydraulic pump?? posted by Hoosierhog on February 06, 2015 at 06:32:17:
The MW hydralic pump is a 'mag pump'.Driven off the distributor drive.Similar to the factory live pump,only a bit bigger.The hand clutch is made to give that M 'live' pto. It mounted to the pinion shaft of the differential.It simply disconnects one (left) rear wheel.The diferential/drivetrain/transmission stills turns till you step on the foot pedal.They were claimed to not slip,that they would hold any M.However,my 'healthy' SuperM could make it slip while hooked to a pulling sled.As far as I know,it has never slipped in the field.And I have several thousand acres behind it.
  Upload Photo  Select Gallery Photo  Attach Serial No List
