Re: Well the head gasket wasn't bad.
Posted by Zachary Hoyt on February 07, 2015 at 11:13:34 from (50.122.166.245):
In Reply to: Re: Well the head gasket wasn't bad. posted by unioncreek on February 06, 2015 at 18:19:11:
In the wet sleeve engines I have been in the O ring seal is toward the lower end of the sleeve. However the point is moot in this case since as has been stated this is a dry sleeve engine.
Zach
  Upload Photo  Select Gallery Photo  Attach Serial No List
