Re: How to clean oil/coolant out of engine block?
Posted by robert major on February 07, 2015 at 15:16:32 from (216.130.83.50):
In Reply to: How to clean oil/coolant out of engine block? posted by unioncreek on February 06, 2015 at 11:52:18:
Hi I just did a Belarus like that. I used brake clean on what i could see. I had the rods out on this one to so the crank drained on it's own, while it was apart and turned over during the work.
I Then cleaned the oil filter( centrifugal wash out on that tractor) re assembled the motor put a cheap oil in and a small can and half of sea foam for oil amount . ran it for a while. then drained it and put the guys expensive winter oil in.
spoke to him last week and he said the new oils spotlessly clean after 30 hours running, no black or water contamination at all.
Regards Robert
  Upload Photo  Select Gallery Photo  Attach Serial No List
