Posted by 87nassaublue on February 07, 2015 at 15:32:22 from (72.152.135.198):
In Reply to: F30 Stuck Clutch posted by DGK on February 07, 2015 at 12:22:08:
I haven't seen what you're working with but it sounds like a taper headed bolt. If it's like a taper headed allen bolt, I have a little trick that will help. An old pulp wooder friend of mine told me about this and it sure works great. If you can find a punch that will fit does in side of the hole in the top of the bolt, you can give it a good rap or two with a good size hammer. That will expand the area of the bolt just below the head and relieve some pressure on the taper. Then, you can remove it fairly easily with an impact wrench. I hope this helps.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
