Posted by Wemedeeres on February 08, 2015 at 08:35:38 from (24.220.88.163):
In Reply to: MW Friction Throttle? posted by pete_5959 on February 08, 2015 at 08:06:18:
Is the friction throttle similar in movement as the toothed throttle lever Asa far as pushing it forward and backward? The reason I'm asking is I aquired the M my grandpa had that I spent many hours on and it has a friction style type of throttle. i never drove any other M's so I didn't know there were different levers. The two H's I drove both had the same sawtooth throttles and the MD had a completely different one.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
