Re: Hydraulic pump gpm
Posted by 87nassaublue on February 08, 2015 at 13:15:09 from (216.130.146.218):
In Reply to: Re: Hydraulic pump gpm posted by Dan Crick on February 07, 2015 at 17:26:52:
That' what I was thinking. It probably would have had a front pump running off the crankshaft. If you have access to an engine lathe, it shouldn't be a big deal to make a coupling shaft. Grainger might have something that could be fitted to it.
  Upload Photo  Select Gallery Photo  Attach Serial No List
