Re: How to install a truck type snowplow on a Farmall H
Posted by a_lead on February 10, 2015 at 16:18:08 from (69.251.128.123):
In Reply to: How to install a truck type snowplow on a Farmall H posted by Al71 on February 09, 2015 at 14:59:09:
third party image
third party image
third party image
third party image
third party image
third party image
Here are pics of what I did w/ one on my 340. This is a factory Myer rig that was designed for a tractor (H, M, 300, 400, etc) with frame rails. I fabricated the channel iron rails on both sides, The 340 is a little narrower than the tractors with frame rails so I had to pad it out a little bit more where the plow frame part bolted to it. It was factory designed to bolt to the transmission tube in front of the axles.
I am happy with how it works. The only thing I wish is that it was 6" wider (and had a hydraulic angle control). With the tires set out a little bit for stability it will run on the plowed snow when the blade is angled.
Edward
  Upload Photo  Select Gallery Photo  Attach Serial No List
