Re: 1962 Farmall 460 Power Steering issue. Asking for guidance
Posted by pete 23 on February 10, 2015 at 21:20:15 from (50.33.19.244):
In Reply to: 1962 Farmall 460 Power Steering issue. Asking for guidance posted by MadDogDave on February 10, 2015 at 18:15:26:
If the steering unit was not "holding pressure" you would not be able to build pressure at the pump unless you had disconnected the line going to the power steering and improvised a fitting to test pressure.. I would simply unhook the steering return line, run it into a bucket and turn steering wheel, gauge in pump test port, and watch the return flow. If pump is no good, flow will fall way off. If flow does not change and is 2 l/2 to 3 gal per minute, the problem is in steering valve or cylinder.
  Upload Photo  Select Gallery Photo  Attach Serial No List
