Re: IHC 340?
Posted by gabeS. on February 11, 2015 at 08:52:24 from (67.78.122.130):
In Reply to: Re: IHC 340? posted by Larry Hardesty on February 09, 2015 at 16:45:30:
Okay guys so I went to the Case dealer and told the guy I wanted to maybe add seals to the tractor he kinda argued that it couldn't be done. So after a few minutes I convenced him to try to locate me some that may fit, he looked up the tractor and found a breakdown that showed 8 valve guilds and 8 seals that go on them. I went ahead and ordered them it set me back 45 bucks They should be in today I will let yall know if they fit. He said since the breakdown shows them then they should be on the engine. We will see, 45$ is worth a shot.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
