Re: 200 Starts by hand, but not by starter
Posted by Jim Becker on February 11, 2015 at 11:03:14 from (173.84.243.159):
In Reply to: 200 Starts by hand, but not by starter posted by thekryptkeeper on February 11, 2015 at 09:20:32:
With that many new parts, you could have one that was bad out of the box (one of the ignition parts, not charging parts). You mention alternator and 6-volt positive ground. Really? A mismatch of parts can cause trouble.
I suspect a bad connection, paint if you are doing clean-up and paint-up, otherwise corrosion/rust.
