Re: 200 Starts by hand, but not by starter
Posted by Al71 on February 11, 2015 at 11:32:30 from (97.95.208.65):
In Reply to: 200 Starts by hand, but not by starter posted by thekryptkeeper on February 11, 2015 at 09:20:32:
Test #1 Connect a wire from the batt to the coil and see if the tractor starts with the starter if so, then the wiring to coil is poor.
Test #2 Check the voltage at the coil as it should be 9 volts or better.
Special note to all of us that paint things pretty is be sure to nuse star washers at all electrical connections because is an insulator.
Al71
  Upload Photo  Select Gallery Photo  Attach Serial No List
