We had a '66 Ford truck with a 352 v-8. Needed a new battery, so we put in a top of the line battery. The thing cranked like crazy, but would only start when the key was released---no starter load. Turned out the new battery was not putting out a true 12 volts. I would suggest putting a voltmeter on the coil "hot" primary & reading voltage while cranking the engine. By the bye, 6 volt alternators are not so uncommon. They are made by Motorola & I believe Delco makes them also. Could be the condenser also.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
