Re: 200 Starts by hand, but not by starter
Posted by old on February 11, 2015 at 11:37:12 from (209.86.226.56):
In Reply to: 200 Starts by hand, but not by starter posted by thekryptkeeper on February 11, 2015 at 09:20:32:
Check spark when your spinning it over with the starter. You need a good blue/white spark that will jump a 1/4 inch gap or more. If spark is weak good chance your starter is pulling to many amps and need to be rebuilt.
  Upload Photo  Select Gallery Photo  Attach Serial No List
