Could also be out of time. Set #1 on TDC, make sure the mark on the flywheel lines up with the mark in front of it. Pull the coil wire out of the distributer and hold the end about 1/4 inch from the nut on the side of the distributer and rotate the distributer until you get a spark. Somehow I don't think it is the starter, as I have started them with very slow rotation. It is true that a slow starter can eat all the current before it can get to the points, though. I assume you replaced the battery cables, be sure the positive one has a good ground.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
