Re: Need your opinion on SC Farmall engine
Posted by Nebraska Kirk on February 11, 2015 at 19:04:24 from (207.91.4.159):
In Reply to: Need your opinion on SC Farmall engine posted by BoonvilleKid on February 11, 2015 at 10:59:03:
You don't need to remove .003" when you hone the sleeves, just enough to break the glaze and put a crosshatch on the cylinder walls, which will only be .0005-.001" Just use standard rings. The ring gap will probably be on the upper end of the specified range, maybe a little over, but you can't get perfect in a worn cylinder. If that concerns you, then spend the money and get a whole new rebuild kit.
