Re: Farmall A Hydraulic add on for front blade
Posted by Notjustair on February 11, 2015 at 20:48:58 from (70.195.1.222):
In Reply to: Farmall A Hydraulic add on for front blade posted by farmallh on February 11, 2015 at 05:50:59:
When I traded for my A it had a unit from a grain truck bolted on beside the generator. It was ugly as sin but worked great. It was self contained including pump, reservoir, and valve. I took it off as I didn't need hydraulics on it but I have toyed with putting it back on mounted to the drawbar and hooked to the PTO. I really don't need hydraulics on it so it would be more of a project than anything and I have enough of those. It was nice that it was contained since removal was a belt and a couple of bolts.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
