Ok, how well is the starter turning the engine over?
Do you get a slow RRRRrrrrr.... RRRRrrrrr.... RRRRrrrrr...?
Do you get a fast WA-WA-WA-WA-WA-WA-WA?
We did have a starter that seemed to be cranking the engine over fine, but the engine would not start. Put a different starter on the engine and it would fire right up. Turned out that starter had a bent main shaft which was causing it to draw excessive current and killing the spark.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
