Re: 200 Starts by hand, but not by starter
Posted by El Toro on February 12, 2015 at 06:01:07 from (96.244.7.206):
In Reply to: 200 Starts by hand, but not by starter posted by thekryptkeeper on February 11, 2015 at 09:20:32:
If the tractor will start easily by a pull start.
You need to have your starter checked. If you have a distributor your battery voltage is too low
when using the starter. Hal
  Upload Photo  Select Gallery Photo  Attach Serial No List
