Serial number breaks will tell. But if not a diesel stage 1 have 2 bolt starter mounting stage 2 three bolt and if calling SMTA stage 3, three bolt starter also. Stage three will have 4 bolts that can be seen on each side mounting the clutch housing or center housing to the transmission housing. 1 bolt inside that can't be seen. stage 1 and 2 have 1 bolt on each side that can be seen without looking up in the bottom of housing.
Diesel stage one have a 3 bolt mount starter without a starter switch on the starter. Stage 2 and 3 diesel use the same 3 mount starter with a switch on the starter. Manual operating linkage is used to engage the starter drive and switch.
If they have original serial plates and parts. Stage 1 Louisville serial # L-500001 to L-504801. Stage two L-504802 to L-512541. No stage 3.
Farmall works serial numbers stage one, F-501 to F-28174. Stage two F-28175 to f-52627. Stage 3, 60001 to 83523.
Some models not exact, example stage two SMD started at serial number 28181, but no diesels were built from 28175 until the 28181 so the 28175 works as the cut off.
This post was edited by D Slater at 08:33:27 02/12/15.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
