Re: Farmall 354 cuts out after 10 minutes
Posted by Janicholson on February 12, 2015 at 15:11:18 from (74.60.94.18):
In Reply to: Farmall 354 cuts out after 10 minutes posted by Steve Wilkens on February 12, 2015 at 07:39:27:
Put a neon voltage tester between ground and the connection on the distributor side of the coil and run it while watching the neon light. If the volt reading There is going to be enough stray voltage to make it flash. If it stumbles and quits flashing as the tractor does, it is likely in the points/condenser.
Another not mentioned issue could be the charge rate of the alternator. If much over 14.8 volts it can over heat the ballast resistor and or coil and cause failure. A test light on the key side of the coil will test the supply side voltage. if it fails, the key/resistor/wiring is faulty.
Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
