Re: Hydraulic pump gpm
Posted by mkirsch on February 13, 2015 at 04:40:04 from (67.253.166.72):
In Reply to: Hydraulic pump gpm posted by Dan Crick on February 07, 2015 at 10:04:41:
I found an online hydraulic calculator:
http://www.calcunation.com/calculators/machinery/fluid%20power/hydraulic-horsepower.php
According to that, the motor you mentioned earlier in the thread can only do about 17HP.
Even the biggest PTO pump that SurplusCenter has at 2250PSI and 21GPM is only about 27.5HP, but that is *BEFORE* losses.
When a snowblower says 40HP, you *need* 40HP to run it decently, at least. You're going to spend a fortune on the industrial sized pump and motor necessary to run it.
Is this a 3pt type snowblower that you're trying to mount on the front?
