Re: 200 Starts by hand, but not by starter
Posted by David G on February 13, 2015 at 07:45:04 from (204.29.138.33):
In Reply to: Re: 200 Starts by hand, but not by starter posted by thekryptkeeper on February 13, 2015 at 06:18:09:
I really believe it is a coil voltage issue, but a wet mixture will ignite easier than a dry one, so choke will help the starting.
I like to test for a timing issue by pulling the coil wire, cranking, then put it in and crank, speed should be about the same if it is OK.
  Upload Photo  Select Gallery Photo  Attach Serial No List
