Posted by D Slater on February 13, 2015 at 08:50:23 from (184.14.187.78):
In Reply to: smd posted by rick deere on February 13, 2015 at 06:39:31:
5000 + were built. Probably not many in 52 because there was only built about 6 months in 52. For some reason only one or none was built in the last 4 months of 52.
Without knowing it will run okay I wouldn't go over a $1000 for a stage one with bad tires and no extras. Just my opinion though. Its a gamble, if it happens to run good it would be worth twice that or more.
Tractor was built in August 52.
Wouldn't hurt to remove the valve cover and check for stuck starting valves and the other valves before rolling the engine. Puts some lube in the top end at the same time.
If you get it a operators manual will tell you adjustments, bleeding fuel system, valve settings and operating info.
This post was edited by D Slater at 08:56:39 02/13/15.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
[More Ads]
