- Rear wheels are reversed and moved in as close as they can go. The excess axle length is then sawed off.
- Right brake pedal is bent in to provide wheel clearance (the right pedal winds up directly above the left pedal)
- A heavy plow underframe is added to transfer plow forces to the drawbar. Supplemental ballast (plate weights) are added atop the rear end of the underframe.
- A 12 volt alternator, halogen front lights and flashers are installed.
- A turned down exhaust stack is installed to limit damage from low hanging branches; also to direct exhaust away from the operator.
- "Special Commercial" license plates are added to satisfy the thieving b@stards in Albany.
AFIK all the tractors are equipped with live hydraulics - thus the preference for stage II "Super" and 3xx/4xx numbered-series machines.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
