Re: 350 diesel or 400 diesel
Posted by Roger46 on February 13, 2015 at 13:03:27 from (69.4.105.12):
In Reply to: 350 diesel or 400 diesel posted by michaelr on February 13, 2015 at 06:34:07:
I have a 350D and the issue other than what others said is the direct start part. They are very hard to start in cold weather. Mine doesn't like to start when the temperature is below 50. Even at 60 degrees it cranks over quite a few times and then really smokes for the first few minutes. I have a completely rebuilt one so it is not because of the thing being worn out. They just didn't have high compression like newer diesels have. They have a manifold heater to heat the incoming air instead of glow plugs. Most of the manifold heaters have burned out and I don't know if you can buy them anywhere. I repaired mine as it was burned out when I got the tractor and so was the one I got that was in a different manifold I bought as mine was broken. I also have an MD which is like the 400D. They has another set of issues. Roger
  Upload Photo  Select Gallery Photo  Attach Serial No List
