Re: 282 head
Posted by Larry B. 1486 on February 14, 2015 at 19:06:07 from (72.106.58.140):
In Reply to: 282 head posted by dundeeaj on February 14, 2015 at 13:35:38:
The heads are the same on a 560 and 660 with a D282 engine. If I remember correct the early D282's had smaller valves than the later ones. The only thing is that the injector pump on a 660 has the RPM's turned up to around 22 or 2300 RPM's and the 560 is set around 1800 RPM. That is how they get a little more hp out of the 660 and the transmission was geared lower than the 560. I don't know where you are getting a I head and L head? Are you looking at a casting letter on the head? Also the head on a D301 used on the 715 combines uses the same head as the D282. The 560 & 660 engines will interchange. Just the injector pumps set at different RPM's
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
