Posted by Jim Naden on February 15, 2015 at 09:39:19 from (70.198.71.41):
In Reply to: 1086 oil pressure posted by gbs on February 14, 2015 at 19:05:26:
gbs said: (quoted from post at 20:05:26 02/14/15) I agree that the mains at ,.002 is is most likely incorrect as for the rod it's close as it was clean and dry when checked, galley plugs were mentioned where are they located,i once saw a 396 chevy that had oil pressure problems and that is what was wrong with it,is it possible to replace the cam shaft and bearing without removing the engine
The engine needs to be removed to replace the cam bearings.
Then, if you don't want to remove the cylinder head, after removing the push rods without removing the rocker shaft, the engine needs to be turned upside down to get the lifters out of the way to facilitate removal of the camshaft.
Then you can replace the cam bushings. Be careful to get the oil holes properly aligned during bearing installation.
This post was edited by Jim Naden at 09:39:49 02/15/15.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
