Re: 656 carburetor slow leak--how to detect and fix?
Posted by mkirsch on February 16, 2015 at 04:47:37 from (67.253.166.72):
In Reply to: 656 carburetor slow leak--how to detect and fix? posted by littlefarmer on February 14, 2015 at 21:38:47:
If it was going into the oil pan, you'd know it.
The 656 has an updraft carb so there is no way for the gas to flow directly from the carburetor into the engine.
In order for the gas to run into the oil pan while the tractor is sitting, it would have to fill up the intake manifold and the air cleaner pipe.
When you tried to start the tractor, it would hydro-lock, or spit a big slug of raw gas out the exhaust if you're lucky. You would definitely know if this was happening.
