Re: Is it possible
Posted by Jim Becker on February 16, 2015 at 09:25:01 from (173.84.243.159):
In Reply to: Is it possible posted by Dieselrider on February 16, 2015 at 04:51:10:
Buy a crank and make sure the timing is set by the book. A Cub is easy to crank start. A battery that won't turn the engine over will still usually fire the ignition system. If the battery isn't strong enough to do that, the engine will die as soon as you unhook the jumper cables anyway.
