Re: Super M-TA Charlynn steering question
Posted by Bob M on February 16, 2015 at 17:27:51 from (67.240.163.172):
In Reply to: Super M-TA Charlynn steering question posted by Rex Simpkins on February 16, 2015 at 15:38:33:
Like IH fan says, supplying the Charlynn unit direct from the remote outlets will cause problems.
The Charlynn steering motor can only take a gallon or so a minute. Attempting to supply it full pump flow (12 gpm) will partially "dead head" the pump. The excess flow will blow off thru relief valve. It will quickly overheat the hydraulics; it also unnecessarily loads the engine.
The better solution is to install a properly sized flow divider (aka. a priority valve) between the pump outlet and the remote hydraulic valve inlet.
  Upload Photo  Select Gallery Photo  Attach Serial No List
