Re: Farmall H Axle bearings
Posted by Charlieu on February 16, 2015 at 19:04:47 from (206.8.2.191):
In Reply to: Farmall H Axle bearings posted by DTK on February 16, 2015 at 17:48:47:
third party image
If you remove the PTO assembly and having the tractor jacked up so you can turn the wheel, you can look through the holes in the bull gear, using a flashlight to inspect the inner bearings while turning the axle. Usually there will also be damage to the bearing cage when a ball breaks in half.
I usually just pull the bolt out of the end of the axle working through the PTO opening and then remove the housing with axle. Then you can replace the bad bearings. I have reinstalled the axle by my self, but it does help if you have a helper. Good luck
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
