Posted by Phil Tibbetts on February 17, 2015 at 03:12:56 from (208.93.14.38):
In Reply to: OIL PUMP posted by gbs on February 16, 2015 at 18:25:31:
I don't know if the dimensions are the gear diameter or the gear width. If it is the gear diameter then the other posts are correct, but if the difference is the gear width then a 1.25" pump would give 25% more flow than a 1". That seems to be a more logical scenario as all that needs to be done is put in a wider center section and gears in the pump to increase the flow. Everything else could remain the same. IMO
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
