Re: Project- Super MTA Diesel?
Posted by D Slater on February 17, 2015 at 05:15:28 from (184.14.187.78):
In Reply to: Project- Super MTA Diesel? posted by DeltaRed on February 16, 2015 at 19:36:37:
Probably the hydraulics would be one of the more costly problems. SMTA gas pump and manifold is different. Unless near end of MD production the front cover on the MD is different than a SMD through 450-D. MD starter won't work on the SMTA and a starter from a SMD stage 2 or SMTAD or late 6 diesels that works is not laying around everywhere. Then you need the linkage to engage starter and the switchover linkage is different. For a user a 400, 450 or some other diesel starters could be used with switch that would eliminate the need for linkage to starter. MD throttle rod would need lengthen and MD steering post a spacer under it.
Just hit the high spots and not all odds and ends to complete. Things like MD hood, fuel tank, frame rails and other should be obvious.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
