Re: Question on tranny gears swapping
Posted by mkirsch on February 17, 2015 at 10:27:37 from (67.253.166.72):
In Reply to: Question on tranny gears swapping posted by lmbky on February 17, 2015 at 09:17:50:
Actually, the 340 has the same rear end as the 460. It has TA and live PTO.
It is an H-sized rear end but I'm not sure how much if any is common with the H lineage.
Only the front half of the tractor is based on the Super C.
