Re: Farmall H Axle bearings
Posted by Owen Aaland on February 17, 2015 at 13:09:05 from (216.47.34.37):
In Reply to: Farmall H Axle bearings posted by DTK on February 16, 2015 at 17:48:47:
It will depend upon what you have for shop equipment. The inner bearing can be replaced with just pulling the PTO and removing the outer axle shaft bearing cap. Then push the axle out of the bull gear and move the gear aside. You can then access the bearing retainer and remove the bearing. It van be done that way but I wouldn't call it the easiest. Since the PTO opening in the H is so small I always remove the deck.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
