Re: Gas tank cleaning
Posted by old on February 18, 2015 at 15:07:51 from (209.86.226.11):
In Reply to: Gas tank cleaning posted by Colbyraper1 on February 18, 2015 at 14:52:49:
Maratic (sp) Acid works well for cleaning a gas tank. Pour some in shake it around then drain it out and wash it out with water and put it some place real warm to dry it out
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
