Posted by robgIN on February 18, 2015 at 16:41:15 from (70.224.35.21):
In Reply to: Farmall F20 head posted by farmallman2013 on February 18, 2015 at 15:18:07:
Where is the crack ? If it is just cracked in the center by the water passage I wouldn't get too worried, almost everyone I have seen is cracked there . No pressure on the cooling system so unless it is cracked in the combustion chamber area or in a port I wouldn't worry about it. I think the heads from a Regular and F-20 will interchange , especially if the same casting number . The late F-20 used V-belt fan and had 3 bosses on the front with holes that the fan mounted to instead of the big stud that the flat belt fan used. Post a picture of the crack if you can and we can give you a better opinion.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
