Re: 806 shift problems
Posted by Les Repair on January 13, 2001 at 17:24:04 from (206.28.174.62):
In Reply to: 806 shift problems posted by gary on January 13, 2001 at 16:15:39:
If pulling back the TA lever helps it come out of gear easier you need to shorten the dump valve linkage. This is the small 1/4 inch rod about 6 inches long attached to the clutch rod. Out here in Iowa the H pattern shift conversions run from $350.00 to $400.00.
Post A Followup
: Re: Re: 806 shift problems
