Posted by Zachary Hoyt on February 19, 2015 at 08:43:48 from (184.12.74.5):
In Reply to: Farmall M Transmission posted by Matt Reinders on February 19, 2015 at 08:20:28:
Some I have had apart just slid off, some took a lot of misery and aggravation to remove. You can take out the bolts whose heads are showing in your photo and the whole front carrier and input shaft gear assembly will come off the tractor. I assume you'll have to remove this anyway to replace any gears. Once it is out you can drive the shaft out of the coupling by supporting the coupling ears and leaving the rest of the unit hanging. This would be best done over a padded surface or with only an inch or two for the unit to drop when it comes loose. Zach
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
