Posted by Bob M on February 19, 2015 at 12:16:24 from (67.240.163.172):
In Reply to: Farmall M Transmission posted by Matt Reinders on February 19, 2015 at 08:20:28:
Try this:
Find a socket with a diameter a bit smaller than the input shaft OD. (I recall using a 1-1/4" socket but it's been a while...)
Center the socket on the shaft, then position the clutch shaft driver coupling over the socket, trapping the socket between the coupling halves. Use suitable bolts and nuts thru the ears on both coupling halves, then gradually and evenly tighten the nuts. This will squeeze the coupling halves together and pull the transmission coupling half from the shaft.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
