A leak down test could help you identify the problem before you tear it down. You turn each cylinder to TDC on compression stroke (both valves closed), apply air pressure, then read the pressure drop and listen for where air escapes from each cylinder: intake; exhaust; rings, etc.
I don't know if a blown head gasket between two cylinders would be enough to roll the engine off TDC or not, just be aware it could roll a few degrees on #4 or #5.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
