Re: Farmall 656 gas questions
Posted by farmallhal on February 20, 2015 at 05:31:47 from (76.2.169.99):
In Reply to: Re: Farmall 656 gas questions posted by MNfarmer on February 20, 2015 at 02:54:16:
I use the CaseIH 30 wt. oil in my tractor as I basically only use the tractor when the weather is above 32 F. It is kept in a closed heated building and would start easy if needed when below 32 F I'm sure. Hope you enjoy your 656 as much as I have mine, Hal.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
