Re: 9 speed transmission?
Posted by Bob M on February 20, 2015 at 11:10:34 from (67.240.163.172):
In Reply to: 9 speed transmission? posted by Ellis Kinney on February 20, 2015 at 10:48:25:
Heisler (also M&W and I believe Schwartz) offered a 9 speed kits. The 9 speed was NOT a factory option.
It works by adding a 2nd set of countershaft drive gears inside the transmission. When engaged it increases the RPMs of the countershaft by 40%(?). This in turn increases ground speed in gears 1 thru 4 by the same percentage. It also increases PTO shaft RPM by the same amount.
9 speed kits do not affect 5th gear speed since 5th is "direct" (countershaft is not used).
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
