Re: Charlynn for Super M-TA
Posted by Paul A Young on February 20, 2015 at 17:39:13 from (69.161.39.42):
In Reply to: Charlynn for Super M-TA posted by Rex Simpkins on February 20, 2015 at 03:34:15:
Three holes on the priority valve 1- pressure supply in 2- pressure out to orbit motor 3-bypass out back to tank.Orbit motor needs #2 pressure in and out goes back to tank. Priority valve can be put on pressure line coming from pump to hyd. box usually. I just put one on my SM-TA on pressure side of hyd. box because I did not need the single action ports on box. I am using a dual valve with pressure relief built in before oil gets to hyd. box to run three point and dual acting remote .Remember two things 1 you have to have the bypass on priority valve back to box and 2 your lever on hyd. box needs to be locked engaged if you use the pressure port on box. Hope this helps ,Paul
  Upload Photo  Select Gallery Photo  Attach Serial No List
